Ok...I got a dyno tune and they said I was running lean so they bumped the fuel pressure up. Sure enough I got home and pulled codes and got 91 and 41 which means I'm running lean. I fixed the problem (forgot to re-attach the 02 ground) and now I get the code 92 which I guess means I'm running rich. Is this because they increased the fuel pressure to compensate for when I was lean or is it something else? thanks in advance for any replies.
