So this is in part with this thread i have going with no luck http://www.stangnet.com/mustang-forums/814294-still-missing.html i went to 2 schucks today and used 2 different scan tools. I get the same thing from both. When i get to the part to start the engine it kills it right away.Then it wont restart unless i give it throttle and it runs rough at first (split sec) then normal. Then the reader says retrieval in progress and thats all it will say forever.It never gives me codes or nothing! I can sit there for 5 minutes or 15 minutes! So WTF could it be?Also i noticed today on my drive,if i'm coasting and put it in neutral and floor it it hits like 5000-5200 and sounds like it's on the rev limiter?It also does this if i get on it in gear. I dont have a rev limiter and the tune is programed higher then that. Plus i launch at 5800 with no problems while racing,and have seen 6200 a few times from miss shifts. Can anyone say where all the grounds are for the computer? Would O2's only cause a problem once warmed up? And could they cause a miss at any speed and in any gear,but not in neutral?peace
john
john
.. the only component that i see that both of us have considering im running stock injectors is the stock fuel pump??.......idk why no one else has chimed in o this..
