codes for my winter car
jimdrechsler
248
I am posting this here because I know how helpful you all are with the mustang i have! Well, I just put the mustang away for the winter today and on the way home in my altima, the service engine light came on. i have the following codes from the "very smart" guys at advance auto. Came at as:
DTC (codes)
P0440
EVAP Emission
Control System
Malfuncion
DTS Pending (codes)
No faluts detected
Thanks guys!
Jim
No such 4 digit codes on a 90 Mustang. All the codes are two digit codes.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Post the exact two digit results & we will try to help you.
sorry for the confusion, but this is for my 99 nissan altima! someone said it is vapors from the gas tank, a possible overfill from last fill up? im going to try and disconnect the battery and see if it resets it.
thanks for replies,
jim
DTC (codes)
P0440
EVAP Emission
Control System
Malfuncion
DTS Pending (codes)
No faluts detected
Thanks guys!
not being a dick, but you came off as one in the last post. this is my original posting. thanks anyway :shrug:
Jim
PJB said:
I actually had a gas cap go bad on a Blazer I had. I replaced it and never got a code again.
OBD-II EVAP codes are very, very often a non-sealing cap. The monitor notices a pressure delta and throws a hissy fit.
thanks for replies. you probably cant tell a faulty gas cap huh? i guess i will just replace it and see if it goes away. it was pretty tight when i took it off and put it back on after the codes were given. someone else mentioned a canister that could be bad or something. any idea where the canister (evap) is??
thanks again-
jim
ps i havent filled the car up yet since light has been on. i wonder if i fill it up and put cap back on if it will make a difference.
I don't know of a means of testing a cap for shadetree folks (though I'm sure Jrichker can whip something up with a soda can, duct tape and Twizzlers. :D ).
If you see the CEL illuminated frequently or quickly (not hard to do on OBD-II EVAP codes that I've seen - as soon as the engine would warm up, the CEL would come on and often stay on fairly solid), I'd cruise by the dealership and ask them to let you borrow a cap from a car on the lot. They very well could let you do that (just for 5 mins worth of idling and testing).
The CC itself (being clogged) is possible but not super likey. The purge solenoid is also possible. Those take more testing or processes of elimination (the specifics of which I'd have no clue about - I don't own one of them new-fangled cars. I just get stuck workin on 'em). :p
Good luck.
thanks again-
jim
yeah, replace it....for some reason here at the Emission tests....they always check your gas cap for something...so somewhere somehow it's important.
