I am baffled with the wonderful suprise of codes that appeared this morning when I started up my car.
I got the following codes with the engine off:
51(ECT above 4.6V)
22 (MAP/BP out of range)
53 (TPS above 4.5V)
54 (ACT is greater than 4.6V)
35 (EVP circuit above max).
67 (Park Neutral Safety Switch)
Plus, I can't pull the codes with the engine on.
All of the codes point to sensor voltages being greater than expected. So what happened? I checked my TPS sensor voltage last night by probing the sensor wire through the weather packed connector with a safety pin. Maybe the ground and signal return wire are now touching? Or maybe the ground is touching the +5V wire in the TPS? I am assuming all these sensors share a common ground.
It is obvious that all these sensors didnt' go bad at once, so I am guessing the following:
1.) TPS is bad after the probe insertion - shorting out all grounds.
2.) Bad main ground at the computer.
3.) ECU went belly up.
4.) Some voltage regulator blew out and is giving more voltage to sensors?
Any clues would be great......Thanx
51(ECT above 4.6V)
53 (TPS above 4.5V)
