Codes Galore - What happened?
  • Thread starter Thread starter tim281
  • Start date Start date Jul 17, 2009
  • 3
First Prev 2 of 3 Next Last
D
dmonty
11
#21
  • Sep 17, 2009
  • #21
i do remember seeing 12v at pin 46 with ecm unplugged while just cranking, and clutch in cranking. i will check others tomorrow i do believe they were very minimal though.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 17, 2009
#22
  • Sep 17, 2009
  • #22
46 shouldnt have any( technically) voltage under any conditions.
Was this and auto Car to begin with?
D
dmonty
11
#23
  • Sep 17, 2009
  • #23
no not that i can tell it has all the 5 speed wiring, i even swapped the clutch switch out of my 93 thinking it may have an internal short and it made no difference.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 17, 2009
#24
  • Sep 17, 2009
  • #24
Posted via Mobile Device
Unplug the O2 harness from the Black 8 Pin connector on the passenger side fender well then do the volatge test again. Let me know.
D
dmonty
11
#25
  • Sep 17, 2009
  • #25
i did that and voltage went away......i think i was on the right path but where do i go from here?
my o2 harness is out of my 93
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 18, 2009
#26
  • Sep 18, 2009
  • #26
Ford had a few variations in wiring done to the 02 harness. Specially from an Auto to Manual or even different year Manual 02 harnesses.
What was the 93, auto or manual?
D
dmonty
11
#27
  • Sep 18, 2009
  • #27
its a manual, it was a four cylinder conversion that my might have been auto, but im pretty sure the donor car was all five speed, is there a easy way to tell by looking at the o2 harness?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 18, 2009
#28
  • Sep 18, 2009
  • #28
Yep, look at the O2 harness from the 02 side, not the ECM main harness side. Look for a looped wire on that side. Each row of PIN's has 4 wires. Look and see if the Looped wire is on the same 4 wire PIN row.
Let me know
D
dmonty
11
#29
  • Sep 19, 2009
  • #29
one row has 3 wires, and one row has 4 wires, the looped wire is the 3rd and 4th of each row
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 20, 2009
#30
  • Sep 20, 2009
  • #30
Looped wire is on the same row of 4 wires? Or on 2 different rows?
D
dmonty
11
#31
  • Sep 21, 2009
  • #31
2 different rows
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
#32
  • Sep 21, 2009
  • #32
What color is the wire thats looped?
D
dmonty
11
#33
  • Sep 21, 2009
  • #33
light blue with white or yellow tracer....i have a pic of it on my phone i can send it to your email or phone if you wanna pm it to me.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
#34
  • Sep 21, 2009
  • #34
PM sent.
It sounds like a 5 speed 02 harness.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
#35
  • Sep 21, 2009
  • #35
I answered in a PM but let me know the answer here in the thread.
D
dmonty
11
#36
  • Sep 21, 2009
  • #36
ok on the ecu side of the connector there is a wire where the empty spot is on the o2 side, and that wire is purple with yellow tracer.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
#37
  • Sep 21, 2009
  • #37
As far as I know, that Purple/yellow wire is supposed to be where the looped Blue/yellow wire goes.
if you can just snip the Looped wire, then go back and do the Cranking voltage test on PIN 46. See what you get.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
#38
  • Sep 21, 2009
  • #38
Another question, what are the wire colors that the Looped wire connects on the ECU side of the connector?
D
dmonty
11
#39
  • Sep 22, 2009
  • #39
the wire colors on the ecu side are blue with yellow tracer (4 wire row), and white with black tracer ( 3 wire row). i snipped the looped wire and checked my voltage when cranking, clutch in cranking, key on, and key off voltages were all minimal. soldered the open on the ecu and plugged ecu in and car seems to run good. still have some codes though, 67, 22, were my my concerns (i had egr and evap out of range do to the fact they're unplugged), 67 had was something with neutral safety switch i believe, and 22 with baro.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#40
  • Sep 23, 2009
  • #40
Because of the sniped wire, your gonna get code 67. I'm pretty sure that to get it to go away, your gonna have to reconnect the looped wire, to the purple/ yellow. But, when you do this, you'll need to remove the ECM and do the PIN 46 voltage tests again, cranking and all.
Code 67 will not let the KOER test initiate.
  • 3
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
