Initial impressions:
MMR Coil-overs: The passenger's side rattles a good bit. People have said coil-overs can be like this and maybe it is normal, but this is worse than I expected. There is a cap that goes inside the top of the tube, but it is a little too small, so the tube has some play. When I go over bumps, the tube rattles and is very noticeable. The driver's side is fine. $169 for the kit. You get what you pay for, I guess.
I'm not done messing with it though; I may be able to figure out something to make it better.
I am still happy with them because I can now set the ride height and go over speed bumps without worrying about scraping.
Strange Struts: Recommended to me by KillerCanary (Paul). Very nice. 10-way adjustable. Other 10-way adjustable struts were closer to $250 each. Mine are currently set to 5. The ride is much less stiff than before. I definately recommend them. $129 each.
MM 4-bolt C/C plates: Very nice. The quality of these is as expected. I got them used from another StangNetter for $100.
- Chris
- Chris
