Coil Packs / Plugs
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Alright so im about to hit 90k and figured i could use some new plugs and coil packs. Whats everyone running? Mods are in sig, im not gonna get real crazy with mods because i gotta save up some money for college and stuff. Anyone running Accel coil packs? Also how hard is it to change coil packs and plugs? Im fairly new to the 4.6, ive had a 5.0 for the past 4 years. And is this a pretty good deal? Summit 06-0009 - Summit® Ignition Tune-Up Kit Value Packs – SummitRacing.com
Thanks
I'm running the Accel COPs, and noticed a nice difference in the way it revved after installing them. It runs a bit smoother, and revs faster. I had a coil fail on me, and used that as an excuse for an upgrade. My car is a few over 90k as well, so I'd say a few of your coils are probably pretty tired, and you should notice a difference with those.
I've run NGKs for four years blown and haven't had one blow out.
Same here; I have TR6s in now. Ironically, it was the Motorcraft plugs that were starting to give me a problem in the past. They only had half the amount of threads on them compared to the fully threaded NGK ones. Nowadays Motorcraft (Autolite) plugs have threads down the whole thing, so it doesn't really matter.
-open hood
-remove connectiong from top of cop
-take a small socket wrench with a 7mm (i think not too sure) socket and losen the bolt fastening the cop into place
-remove cop with your hand. make sure to pull out the cop by its rubber boot.
-blow out plug well with compressed air to remove any and all debris
-remove spark plug
-replace spark plug to 22lbs/ft
-follow instructions bckwards, putting dielectric jelly on cop connection and tip of coil. also spray the outside of boot with some electric scilicone spray
-press cop back into place
-tighten bolt
-plug the electrical connection back onto boot with a little more dielectric jelly on the connector
this should take you the better part of an hour. you do NOT need to remove you fuel rails.
anyone have any write ups on how to install them? like i said im new to 4.6's, i could change the plugs in my 5.0 in about 15 minutes, but seriously doubt its gonna be that easy with a 4.6
Its really not difficult, just a matter of having the right collection of sockets, extensions and elbows. You could probably do it under an hour easy...
You can get just the lower "boot/spring" section of the C.O.P. assemblies from O'Reillys Auto for $3.20 each. They slide right off. These lose their insulative properties over time just like a spark plug wire does.
There is no sense in replacing all (8) $76 each C.O.P. assemblies when the real culprit are just the boots.
GT
