coil spring again
BILL S
18
NASVILLE, TN
I`am replacing the coil spring with frpp "c" springs in my `93 vert , i have one in and can see that it has moved close to the second hole but not covering it ,will this position be ok. I know that the end the spring has to be between the two holes but does it have to be perfectly centerd.
I don't know that there's a 'perfect' setting. I simply go for having both springs sit in the same spot in the pocket (symmetry).
If you're between the two index holes, you should be fine.
MHO.
Good luck.
