Yep everything seems pretty much normal. Actually my strut bolts stick up ALOT further out of the CC plate, but I wanted to make sure they wernt in a bind and compressed too much lol....after having my tokico snap on my I want to take 0 chances.
As far as your ride height is concerned, all you have to do is jack up one side of your car at a time, remove your tire, then get a C clamp and adjust it to hook into those slots on the adjuster, and then turn awayMark where it started and turn it until its about 3/4s of an inch from where you started....then repeat on the otherside. Problem solved
So you used a C-Clamp as a wrench for the coilerover adjuster nut?
