coilovers
I no next to nothing about these besides that they allow adjustablitiy of the hieght of you car. Can someone just explain them to me? If i get wieght jacker lower control arms will i need rear coil overs too? Im sry if i sound wicked stupid but i dont no much about suspension.
and if i get this kit what else will i need to get
http://www.coolblueperformance.com/index.asp?PageAction=VIEWPROD&ProdID=507
thanks a lot guys
thanks a lot guys
Just do a search for "coilover" you'll get all the info you will ever need.
When you get the right set of spring rates with the right shock you can greatly improve handling, depending on your application.
You don't need coilovers for the rear if you get weight jacker lca, but I would invest in beefing up the torque boxes.
Be careful of doing rear coil over's without the aid of reinforcement for the rear shock towers. They have a tendency to crack if they are not reinforced.
Fot the fronts most people run CC plates to help this but nothing for the rear. :nono:
