cold air intake fitment
  • Thread starter Thread starter NKau
  • Start date Start date Feb 27, 2007
NKau
1,346
Jefferson, WI
Feb 27, 2007
  • Feb 27, 2007
Wondering what you guys have had the best luck with. Any problems with any of the cheap e-bay kits? I just need something that will mate to a 75mm MAF and a 65mm TB and not look like poo. I'd reuse the factory setup, but am guessing there's no good way to couple a big MAF to it.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Feb 27, 2007
  • Feb 27, 2007
I ran the stock box and inlet tube with my 75mm bullet meter...A/F reading with that set up was FLAT and easy to tune.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Feb 27, 2007
  • Feb 27, 2007
Should note I currently run a C&L inlet pipe with the stock box and Pro-m 75mm bullet and it looks good and works excellent too.
NKau
1,346
Jefferson, WI
Feb 28, 2007
  • Feb 28, 2007
Glad to hear I can keep the stock pieces! I take it I'll need an inlet pipe to get it to mate up to my stock box? Do you by chance have a part number for it? Thanks a bunch DMAN.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Feb 28, 2007
  • Feb 28, 2007
704 Is the one I have installed..I polished it but the casting was a ****** so I'd recomend you go with the polished option from C&L if you want the bling. The meter will fit nicely with tha pc...the couplings SEEM to big but will colapse nicely with the supplied hose clamps.
http://www.cnlperformance.com/inlet.html
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Feb 28, 2007
  • Feb 28, 2007
To add you may need to knock a little material off the end of the pipe to keep the part off the strut tower (mine was CLOSE but does not touch). The choice to remove the material is just that, a choice, it will fit AS IS with Pro-m and the stock box and stock box/meter coupling.
JChalfan
551
Bellevue, WA
Feb 28, 2007
  • Feb 28, 2007
I don't think I've had to do anything different with either my C&L or Pro-M 77 (maybe 75? don't know for sure) MAF's. They fit the factory tubing on both sides.
M
MYSTICSVT
349
Meridian, Idaho
Feb 28, 2007
  • Feb 28, 2007
I'm running the C&L 76mm MAF sensor with their Tru-Flow intake tube on mine. No problems with fitment or driveability with the stock airbox(flat panel K&N, no silencer).
modusmortis
54
  • Feb 28, 2007
running stock intake setup with my 75mm pmas
NKau
1,346
Jefferson, WI
Mar 1, 2007
#10
  • Mar 1, 2007
  • #10
Thanks for the input guys. I'm going to try and keep the factory stuff if I can help it.
  • dan50
  • Jul 18, 2026
dan50
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Engine BBK Cold Air Kit Rework
  • AeroCoupe
  • Apr 18, 2023
2K
Fox 5.0 Mustang Tech Apr 30, 2023
AeroCoupe
Engine Air intake manifold leak advice
  • mikeah
  • Dec 21, 2022
4K
Fox 5.0 Mustang Tech Dec 30, 2022
General karthief
