I know that there is a lot of debate about the air silencer, whether to remove it, keep it, or shorten it. How about removing the air box? Rather than worry about grabbing air that is a few degrees cooler, allow the air filter to have access to more air. For example, the Steeda High Flow Air kit is largely open, except for a metal plate protecting the air filter from the heat of the engine. Has anyone tried to run with an open air filter? What were the results?
No doubt there is cooler air in the fenderwell, but if you feed the MAF with different air flow characteristics then it will in turn tell the computer to make the incorrect adjustments.
You can sit and analyze all you want, if you feel better that you're getting 3 more oxygen molecules than stock, go for it.
Damn, I bet you could feel those 5 molecules too!
