  • 1994 - 1995 Specific Tech
collapsed lifter?
  • Thread starter Thread starter schacher94gt
  • Start date Start date Oct 27, 2009
schacher94gt
9
  • Oct 27, 2009
Over a year ago I put in the e303 cam with new lifters and just recently I had a sound coming from the passenger valve cover. We pulled it and found to what looked like a collapsed lifter. They were under warranty so I put brand new ones back in started it up and the sound was still there . Is there something that could be making them collapse? I have stock length gt pushrods and rockers on gt40 heads. Also my oil pressure was inconsistent while this was happening...oil pump finally going out maybe?
thanks
Alex
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 27, 2009
  • Oct 27, 2009
You may have a blocked oil passage going to the lifters. It could also be physical damage to a cam lobe. Start it up with the valve covers off and check how consistent the oil flow is out of each rocker.
Kurt
schacher94gt
9
  • Oct 27, 2009
that was my next step to pull the valve covers. i was adjusting my timing when it started and for a couple weeks before hand my dummy oil pressure gauge would drop to 0 when my rpms would drop past 1000. if that helps w/ anything?
thanks again
Alex
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 28, 2009
  • Oct 28, 2009
As long as you're getting 20+psi at idle, and 40+psi above 3000rpms, the oil pressure shouldn't be an issue.
Kurt
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
Y
Engine Oily cylinder- bad lifter relationship
  • Yoyoda
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 16, 2024
Yoyoda
Y
