come on need help pro m
  • Thread starter Thread starter noslow1986
  • Start date Start date Sep 4, 2006
N
noslow1986
274
oswego Il
Sep 4, 2006
  • Sep 4, 2006
is a 80mm to big i have trick flow intake and cold air induction and 70 mm throttle body gears pulleys and msd ingition and other bolt ons i already purchase it form ebay it said for 19 or 24 injectors what should i do i dont like c and l. did i just waste a hundred dollars
T
TheUser
1,859
Springfield, MO
Sep 4, 2006
  • Sep 4, 2006
Start researching before you buy stuff or you'll waste tons of money.
The pro m sensor should be calibrated for either 19 or 24 lb injectors, not both. Mine has the calibration on the top engraved in the plastic. The most important thing is that it is calibrated for the size injectors you have. Secondly, don't make the mistake of putting a Pro M sensor on a C & L MAF tube because they aren't interchangeable.
Lastly, I'm no expert, but I'd say the 80mm MAF tube might be a little big for your combo. You might not make as much power as you would with a smaller one, but I'm not sure what else it would cause.
What size injectors do you have?
71swing
199
Omaha,NE
Sep 5, 2006
  • Sep 5, 2006
The 80mm should do fine, but as said above it can only be programed for one size injector only i'm sure that is your problem. find out what the proper size it needs or you may have wasted money on a product that is no longer made by a company that is no longer around. (was a great company)
N
noslow1986
274
oswego Il
Sep 5, 2006
  • Sep 5, 2006
i have 19 pound injectors but the person i bought it from said it can be used for stock or 24 lb injectors but i know its one or the other
04sleeper
2,674
14
89
Dallas, TX
Sep 5, 2006
  • Sep 5, 2006
The Pro-M 80mm will be calibrated for only 1 size injector, not 2 like stated.
You will not loose ANY power by it being too big, even if your motor was bone stock it is not too big.
If you can not read the numbers and figure out which calibration it is then you can send it back and they can tell you what calibration it is for.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 5, 2006
  • Sep 5, 2006
If time is of the essence, try emailing them or even better calling them. Give the code on top of the MAF and they should be able to answer that for you.
With it being an MAF, I wouldn't say it would hurt your power. You don't need the flow now, but you could later. Good Luck with the outcome.
D
Daggar
3,902
  • Sep 5, 2006
There's a link to their website in my sig.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Sep 5, 2006
  • Sep 5, 2006
Like the chicks in the "movies" say: "bigger is better" . you're ok and didn't waste the $$.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
