  • SN95 4.6L Mustang Tech
Comp Cams
  • Thread starter Thread starter NPIGT
  • Start date Start date Sep 2, 2005
N
NPIGT
96
  • Sep 2, 2005
What type of Comp Cams would you suggest for a PI headswapped Car? And if any of you have comp cams where did you get them and at what kinda cost? thanks guys and gals!
98blackmagic
386
wouldnt you like to know
Sep 2, 2005
  • Sep 2, 2005
If you can get the September 04 issue of Muscle Mustangs & Fast Fords. There is a great write up on all six of the comp cams. They say the xe262 would be the best choice for a daily driver n/a or if you have forced induction go with the xe274's. I have a 4.6 being assembled now at my speedshop that has forged pistons, new rings, bearings, rods........ Stage 2 PI heads from Heads up Performance, 30lb injectors and the xe278 cams . I am going to run a blower on the motor as well, so with the ported heads and the blower the 278's were the best choice for the maximum power from the combo. Custom tuning is required for me but if you go with the xe262's the Comp book says custom tuning is not required, but of course I would anyway I'm sure it will give a few extra ponies. Good luck
T
TGJ
1,049
  • Sep 2, 2005
The cheapest place I know of for Comp Cams is http://www.modularperformance.com. If it was my car, I would look at the Comp 270's as well, if you plan on staying N/A.
98blackmagic
386
Sep 2, 2005
  • Sep 2, 2005
Yea those would be a good choice but they recomend ported heads with those cams, all for the better though, more POWER!
mogs01gt
3,113
30
119
Ohio
Sep 2, 2005
  • Sep 2, 2005
I got mine from Summit racing and they are pretty sweet off the shelf cams
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Sep 2, 2005
  • Sep 2, 2005
Does anyone have the specs on the Comp Cams for a wild n/a set up ? I'm looking for something in strict competition with VT Engine Stage II cams. Thanks.
mogs01gt
3,113
30
119
Ohio
Sep 2, 2005
  • Sep 2, 2005
do it right the first time and get the VTs. I wish I did .
T
TGJ
1,049
  • Sep 2, 2005
If you are looking for a Wild N/A cam, look at what Crower has to offer. As for the VT stg II's, I wouldn't want a cam with such a tight LSA as that one has.
W
WOT
2,817
Regina, Canada
Sep 2, 2005
  • Sep 2, 2005
Better yet call up MPH and get a custom grind.
J
jimfitzgerald
6,672
#10
  • Sep 3, 2005
  • #10
I got my first set of Comp cams on a group purchase from somewhere that I don't remember. They were custom grinds spec'd out by Dennis Miles from Comp. I made 560 rwhp with them. I got my second set from Modular Powerhouse as part of my engine rebuild they did. They were spec'd out by Tim along with his race ported heads and larger valves. I made 660 rwhp with these. I recommend a set of custom Comp cams from MPH.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Sep 3, 2005
#11
  • Sep 3, 2005
  • #11
Alright, that sounds cool. I'll probably look into getting a set of custom cams then, but the VT Engine Stage II cams for some odd reason look pretty good. I've looked at the Stage III cams for a n/a application on Modular Performance home page, and they all seem to have a 113 lsa. Wouldn't a tighter lsa, like say "108" be better for a n/a application ? I know that is what VT Engine uses on theirs, and they make good power.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Sep 3, 2005
#12
  • Sep 3, 2005
  • #12
are custom grind Comp Cams with these specs ok for a n/a daily driver?
Specs:
Duration:
Intake@50: 234
Exhaust@50: 242
Lobe Separation: 114 degree.
Valve Lift: 550.
RPM Range: 1800 to 6000 RPMs.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Sep 3, 2005
#13
  • Sep 3, 2005
  • #13
Specs:
Duration:
Intake@50: 234
Exhaust@50: 242
Valve Lift: 550.
The lobe seperation seems fine for daily driving. The lift specified is 550, but is that for both the intake and exhuast ? If both the intake and exhuast have the same lift, it sounds like a blower cam. For a n/a application, you probably want a bit more on the exhuast side than the intake. The duration seems fine as well.
T
TGJ
1,049
#14
  • Sep 3, 2005
  • #14
Specs:
Duration:
Intake@50: 234
Exhaust@50: 242
Valve Lift: 550.
Ummm, I would not pay extra for those specs. The Comp XE270AH is almost identical to those.
270 Specs:
Intake@50: 234
Exhaust@50: 238
LSA: 113
Valve Lift: 550
streetstang03
unModerator
Dec 27, 2003
Sep 4, 2005
#15
  • Sep 4, 2005
  • #15
im not paying extra
J
jimfitzgerald
6,672
#16
  • Sep 4, 2005
  • #16
Unless they have changed their policy, custom Comp cams are the same price as "off-the-shelf" Comps.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Sep 4, 2005
#17
  • Sep 4, 2005
  • #17
Anyone have any good tech articles on learning more about cams for the 4.6ltr ? I'm going to come up with my own custom cam design for my application, and I think I need to know more about how the cams work on the 4.6.
Blown00GTAuto
182
Washington DC
Sep 6, 2005
#18
  • Sep 6, 2005
  • #18
Dark Knight GT said:
... I'm going to come up with my own custom cam design for my application, and I think I need to know more about how the cams work on the 4.6.
If had the need for custom cams I'd let the pros do the specs. Companies like 'Motor Machine & Supply' in Tucson Arizona use a master software program to calculate the best cam events for an application. Computations are based on many top-notch profiles developed by several of the major cam manufacturers, and the service is relatively inexpensive. As far as I know, most specs they do are for track cars and the results are highly reliable.
Nevertheless I'm ok with the specs on OTS Comp 270's .
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Sep 7, 2005
#19
  • Sep 7, 2005
  • #19
Alright, cool. I guess I'll leave it up to the pro's to decide on then. I was just having another one of my "brain storms", and just figured I'de look into it.
N
NPIGT
96
#20
  • Sep 7, 2005
  • #20
I think I am going to go with some VT stage 2 cams. I have heard impressive numbers and no complaints.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
