Comp polymers upper intake
  • Thread starter Thread starter 1993SSP
  • Start date Start date Jun 1, 2004
1993SSP
1,194
Ky
Jun 1, 2004
  • Jun 1, 2004
I was looking at the comp polymers upper intake in jegs, Anyone in here have any experience with them? I am going with a thumper combo and a tmoss lower intake. Im building a good solid streetable motor and wondered if there would be any positive or negative things with this intake for my application, thanks!
cleanLX
976
537
144
Jun 1, 2004
  • Jun 1, 2004
no experience running one.
the short runners are not designed to work optimally in the lower rpm range, so, in theory your hp/tq would be realitivly dead, or, out to lunch below 3000-3500rpm.
However, given that you are only running 130-135cc intake runner, regardless of what gets slapped on top of them they should make respectable lower rev performance.
My 'combo in the works' consists of ported E7's and a Tom Moss lower along with an aggressive cam. The cam was not designed to do much below 3500 and yet with the small runner heads it'd still smoke the tires from a 2500rpm roll in second gear(stock upper).
I've contemplated running a box atop my combo, but am not ready to dish out 300 bones to take advantage of a few peak cfm.
The stock upper flows mid 190cfm... before plunking down 300 bones, I'd have the heads flow'd to ensure that the upper is really restricting you enough to warrent the upper intake swap. Remember, peak lift(flow?) is only reached once per revolution, but "all" other lifts are utilized twice per revolution... keep that in mind once you get your flow numbers.
Again, the theory is that it'll 'kill' low end power, so, may not be something you want for a street car.
My guess is on a street car you'd not be happy.
Launching at 6250 on slicks and beating it up on the track where 95% of the run is above 3500rpm may be a different story.
Hope that helps.
germantowngt
26
Germantown, MD
Jun 6, 2004
  • Jun 6, 2004
Hartman Box Intake
Thats what they were before they were bought by Comp Cams. I've had mine for about 9 years now. If your motor is stock you'll not like this intake. You'll lose a lot of power down low. This intake is made for forced induction. It really wakes up then.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • dan50
  • Jul 18, 2026
dan50
I
Engine Explorer GT40 Intake & Heads
  • Iceman1998
  • Mar 14, 2024
2K
Fox 5.0 Mustang Tech Mar 16, 2024
86HO5.0
