compression and boost?
  • Thread starter Thread starter diddylx50
  • Start date Start date Jan 27, 2004
diddylx50
157
  • Jan 27, 2004
I was wondering how much boost i could run on pump gas with the 10.4 to 1 compression. I can get a great deal on a vortech a-trim w/power pipe,msd btm, pro-m 80mm mass air, and a custom burnt chip. The motor is a high compression 306 w/ edelbrock heads, e-cam, RPM 2 intake and has dynoed at 296hp and 310tq (air/fuel at 11.5...still got some more power left in it) w/ a non lockup converter. The a-trim has the stock pulley on it and maxed out at 6psi and i would like to know if its possible for me to put it on my car without hurting the motor.
Andrew
mike keirstead
1,121
ROLLING A JOINT
Jan 27, 2004
  • Jan 27, 2004
If you have a stock 5.0 block,crank and rods I wouldn't run ANY boost with 10.4:1 compression. But that just me.
diddylx50
157
  • Jan 27, 2004
Its a DSS Pro bullet 306 w/pro lite pistons if that helps any
mike keirstead
1,121
ROLLING A JOINT
Jan 27, 2004
  • Jan 27, 2004
Even still. It's not a 4 bolt main. I would think 9:1 would be the most I would run.
NKau
1,346
Jefferson, WI
Jan 27, 2004
  • Jan 27, 2004
I don't think it can be done. Your compression is already on the edge of what pump gas can handle. High compression + boost = carnage.
84blkstang
544
Springfield MO
Jan 27, 2004
  • Jan 27, 2004
i read somewhere on here that the boost and compression fight and tend to throw things around if that helps
diddylx50
157
  • Jan 28, 2004
thanks for the opinions everyone! Why is it that LS1 motors have 10 to 1 compression and run 9psi and they are alright? Even tho im not a big fan of nitrous(had a nasty backfire) i'll just go with the NX kit that ive been lookin at.
Andrew
G
go4it
206
Virginia
Jan 28, 2004
  • Jan 28, 2004
http://www.motorsportsdigest.com/forced2.htm
mike keirstead
1,121
ROLLING A JOINT
Jan 28, 2004
  • Jan 28, 2004
The Ls1 has a beefier block and internals.
G
gtconv91
currently Iraq/Italy/Wyoming
Jan 28, 2004
#10
  • Jan 28, 2004
  • #10
You have a brand new D.S.S 306 w/ edelbrock aluminum heads, E303, and a RPM 2 intake and only getting 296 ponniesand 310 Ft lbs of torque?? I have a little over that with a factory 302 w/ gt-40p's with very like work, 1.72 roller rockers, and a cobra intake the biggest difference is mine has 130,000 miles. Juice is almost you only "forced induction" with the compression that high with out runnin, race fuel.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 28, 2004
#11
  • Jan 28, 2004
  • #11
Cause the kits the LS1's use pull a lot of timing to compensate for the high compression ratio.
diddylx50
157
#12
  • Jan 28, 2004
  • #12
My car only makes 296rwhp and 310rwtq at the wheels cause of a non-lockup converter. If my car had the drivetrain loss that a stick does it would make in the range of 320hp and 335tq. This motor is still emissions legal and has had no tuning at all.
G
gtconv91
Jan 30, 2004
#13
  • Jan 30, 2004
  • #13
What you just put it on the rollers to see what it gets. Then pulled it off?? Tuning helps especially if you want a power adder
diddylx50
157
#14
  • Jan 30, 2004
  • #14
I ran out of dyno time. I made 3 pulls first being 291hp then i upped the fuel pressure by accident and it dropped power to 286hp. On the last run i dropped the fuel pressure down and came out with 296hp. I recently broke my fuel pressure gauge that I had on the fuel line so im unsure what psi the fuel pressure is at.
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
