Compression/Leakdown testing - must engine be warm?
  • Thread starter Thread starter SadbutTrue
  • Start date Start date Mar 9, 2009
SadbutTrue
2,391
Thousand Oaks, California
Mar 9, 2009
  • Mar 9, 2009
I bought a leakdown tester (well, something I'm going to turn into one, anywya) last week with the intention of doing a compression and leakdown test on my engine, which has been torn down for 2+ months. I was all set to get started when I noted the web sites I was using for guidance said that for both tests you need to have the engine warm.
So yeah, I'm basically wondering if its worthwhile to do the tests now or if I should put it together, fire it up for a few minutes then do ithe tests.
socalwrench
26
  • Mar 9, 2009
generally, yes, the engine should be at the normal operating temperature. this eliminates any possibility for variation in regards to piston material (expansion) and piston ring design (IE gapless rings).
since the engine is not in the car, or in running condition- you can still perform the leakdown test. just prime the oil system and rotate the engine by hand several times. this should get some oil up the cylinder walls and into the heads.
mrmustangman357
763
Mar 9, 2009
  • Mar 9, 2009
isnt your engine still in the car? Just make sure the oil is on the cyl walls as suggested. up at operating temp really isnt too important. you are mostly looking for variation cyl-to-cyl so everything is equally loose.
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Mar 9, 2009
  • Mar 9, 2009
i was gonna say, compression checks are pretty routine and mandatory in planes, and If we can't get up to temps, we just squirt a little oil in each cylinder before the check. do that same and you should be fine.
SadbutTrue
2,391
Mar 10, 2009
  • Mar 10, 2009
Yeah, engine's still in the car. So just squirt some oil in the spark plug holes and go for it? And should I still run both tests?
CraigMBA
783
Orange, CA
Mar 10, 2009
  • Mar 10, 2009
I'd do it dry first. If you have a problem, you'll find it dry.
rbohm
6,698
550
204
tucson,az
Mar 10, 2009
  • Mar 10, 2009
i agree with craig, do it dry first. if you get any strange readings, then do a wet test as that gives you a base to determine where any issues might be. as for temperature, the engine doesnt have to be at operating temperature to perform these tests. the numbers might be slightly lower cold than warm, but they will be the same percentage lower across the board and thus a non factor.
SadbutTrue
2,391
Mar 10, 2009
  • Mar 10, 2009
Is there any downside to squirting some oil in?
But thanks, hopefully should have something tonight.
CraigMBA
783
Orange, CA
Mar 11, 2009
  • Mar 11, 2009
If you find a problem dry, you can squirt it and see if it helps. If it does help, apart it comes.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • dan50
  • Jul 18, 2026
dan50
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
