Compression test results...
  • Thread starter Thread starter 86Five-0
  • Start date Start date Apr 29, 2004
86Five-0
806
New Jersey
Apr 29, 2004
  • Apr 29, 2004
I did it after comin home from class which was a 25 mile drive so the engine was nice and warm. Just recently did an oil change to 20W-50. Here are the results: (btw I recorded after each crank and did it 5x, averaging out all the #'s)
'86 5.0 with 135,000mi. on it.
Cyl # Comp.
1 145
2 140
3 145
4 135
5 145
6 145
7 135
8 145
These are the averages I took rounded off, I didn't get anything lower than 137 but listed 135. I did 5-7 cranks until the gauge went no further. First crank shot up to around 90 and last went up to about 190 at the 5th crank pretty consistently between cylinders. Let me know what you guys think.
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Apr 29, 2004
  • Apr 29, 2004
Not to bad, but could be a little better for a 5.0 especially an 86 5.0 which had a bit more compresion than the 87 & up 5.0's. The 87 5.0 I had in my stang before the 408 had 205,000KM on it, and it averaged 158-165 all the way around! I was very impressed. Overall though, I would say what you have isn't to bad... it could be alot worse. I would take that 20W-50 out as well. Your engine DOES NOT need such a thick oil. It does nothing but rob horsepower and gas milage. Throw some 10W-30 or 5W-50 Synthetic in it and you and your motor will be alot more happy. 20W-50 does not lube or increase your engine life any better.
86Five-0
806
New Jersey
Apr 30, 2004
  • Apr 30, 2004
Yeah, I had just recently changed the oil and put in the 20w-50. You think it's bad on the the engine? I had been runnin' 10w-30 for almost the past 2 years. As for the compression, would worn out valve seals give me lower compression? The car does smoke a little bit and burns some oil but not that bad.
408stroker5.0
Mar 10, 2004
639
Apr 30, 2004
  • Apr 30, 2004
The 20W-50 won't hurt the engine, but like I said there is no sence in having it as it rob's HP and mileage.
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
  • dan50
  • Jul 18, 2026
dan50
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
