Computer only allows 24 degrees adv?
  • Thread starter Thread starter eliaseje
  • Start date Start date Aug 16, 2004
eliaseje
466
Ohio
Aug 16, 2004
  • Aug 16, 2004
Right now I have my timing set at 32 degrees adv. I have heard that the ECU will only allow the timing to advanced to 24 degrees? Is this true?
frink84
43
Forney, TX
Aug 16, 2004
  • Aug 16, 2004
isnt even 24 degrees a bit high? arent stangs set at like 10 degrees factory? i thought like 15 degrees was a damned advanced timing....
eliaseje
466
Ohio
Aug 16, 2004
  • Aug 16, 2004
well i have trickflow twisted wedge heads and Trickflow stage 1 cam and the instructions on the heads say to run the TOTAL timing at 32 to 34 degrees timing. Is there a difference between regular timing and total timing?
G
gt90stang
568
  • Aug 16, 2004
Yes, the PCM adds timing based on load, altitude, rpm and throttle position. My A9P will get up to 50* BTDC under light load conditions.
Good Luck, Don
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
Digital Self-tuning Forum May 2, 2026
Mustang5L5
