Computer tune after cam?
  • Thread starter Thread starter 88 Fox GT
  • Start date Start date Sep 3, 2004
88 Fox GT
1,674
Iowa
Sep 3, 2004
  • Sep 3, 2004
I'm fairly new to modifying an EFI engine. So, if I were to install a Trick Flow cam, would the computer need retuned for the bigger cam? For instance, the injectors would need to know that they would need to flow longer than usual because of the increased duration and flow more because of the increased lift. Correct? Or would the MAF meter automatically tell them how much more air is being pulled in and how much longer it's being pulled in and automatically compenstate?
BTW, would the TFS-51402001 cam be a good one for my combo in my sig? It has 224/232 duration @ .050in and .542/.563 valve lift.
Basically, the engine will eventually be a 331 or 347. Hence the 75mm TB and 30# injectors. I just basically want a good cam that I will be able to use in the stroker when it comes time, but have it help this engine eat up all the fuel it's recieving for the time being.
88 Fox GT
1,674
Iowa
Sep 4, 2004
  • Sep 4, 2004
No one has put a new cam in their 5.0?
Scorcher2005
883
South Carolina
Sep 4, 2004
  • Sep 4, 2004
which tfs intake do you have? street, track heat, R?
88 Fox GT
1,674
Iowa
Sep 4, 2004
  • Sep 4, 2004
I want to say it's a track heat, but am not 100% sure. All parts were on it when I bought the engine so I don't remember what he said it was. I think it may be a track heat though.
Scorcher2005
883
South Carolina
Sep 4, 2004
  • Sep 4, 2004
w/ that lift you have to make sure your valves arent gonna be hitting your pistons. You may even want to consider the stage 1 cam (tfs-51402000)- many ppl here run them w/ good results.
88 Fox GT
1,674
Iowa
Sep 4, 2004
  • Sep 4, 2004
Ok thanks. Do you know if the computer needs a tune after installing this cam?
04sleeper
2,674
14
89
Dallas, TX
Sep 4, 2004
  • Sep 4, 2004
All you have to do is disconnect the battery for at least 20 minutes. Then it should relearn new items installed on your engine. It is not nessecary to have the car custom tuned with a chip in order for it to run ok.
D
dude5l
201
Grande Prairie, Alberta , Canada
Sep 4, 2004
  • Sep 4, 2004
Ideally getting a chip burnt would be the way to go, but not necessary. If you plan on doing mods in the future, hold off on the chip until your done.
88 Fox GT
1,674
Iowa
Sep 4, 2004
  • Sep 4, 2004
Ok thanks!
M
mooktank
237
#10
  • Sep 4, 2004
  • #10
did i miss it or did he say hes going to have mass air or speed density.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
I
289 cam break in help
  • iaff284
  • Aug 19, 2022
1965 - 1973 Classic Mustangs -General/Talk- Aug 19, 2022
iaff284
I
W
347 EFI Low Power
  • w_jake17
  • Jul 8, 2022
  • 2 3 4
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2022
TOOLOW91
