Computer Tuning
  • Thread starter Thread starter chobracobra
  • Start date Start date Nov 25, 2004
chobracobra
175
jersey shore
Nov 25, 2004
  • Nov 25, 2004
I have a 1989 5.0 that is heavily modded. I have heads, cam, intake, exhaust and AOD with a Bauman valve body and 3:73's. The only thing i havent done yet is computer work. Do all these parts even produce their potential with the stock computer commands? I sometimes think about the fact that the engine is controlled by a computer and not entirely by airflow like our ancestor cars and if the computer "knows" the parts are there; if it matters. i would like some recomandations on some chips. price is not a factor i just want quality. by the way i am running stock timing too.
C
crunchie12268
599
Manhattan, KS
Nov 25, 2004
  • Nov 25, 2004
What kinda Heads, Cam and Intake...
chobracobra
175
jersey shore
Nov 25, 2004
  • Nov 25, 2004
Gt-40 Iron Heads
E-303 Cam
Cobra upper and lower manifold
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 26, 2004
  • Nov 26, 2004
The Mass Air computers are "smart" enough to compensate for mods & the changes in airflow they create.
A custom chip is useful to tailor the A/F ratio and eliminate idle problems if you have them. Don't expect a chip that you order from a speed parts warehouse to do the same job as one burned using a dyno run for the chip programming input.
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Nov 26, 2004
  • Nov 26, 2004
If you've changed the MAF then most likely the new calibrated one could use some adjustment this will show significant gains in driveability and some power. Stock program is actually pretty good but timing tables are pretty tame. You will see more gains from modding the stock computer with aluminum heads but will definitely see gains with your heads just don't expect to see 40+ HP increases.
Digital Tuning Chip tuning in 2025, what are my options?
  • AnthonyA1234
  • Feb 3, 2025
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 17, 2025
AeroCoupe
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
T
Forced Induction On3 turbo on stock 89 with 87K miles --suggestions
  • tank76
  • Aug 2, 2023
8K
Fox 5.0 Mustang Tech Aug 27, 2024
AeroCoupe
