Concern with cooling system flush
stangg01
129
I plan to flush my cooling system this weekend. I read another thread where someone had the thermastat housing bolt break off. What should I do to prevent this? WD40 the night before?
Anything else?
Doesn't matter if he overtightened it before or not, they're known for being stuck on from coolant seeping through and drying inside the threads holes. Sometimes you have no choice but to snap it off, crap happens, just try to lube it up (WD-40) good before you go to town on the bolts
Just too make sure you dont snap the bolt you could aways break the bolt loose with your torque wrench, typically I dont use my torque wrench for loosing a bolt, but thats why the torque wrench do have a reverse. Torque on the themo housing bolts is 15-22 ft/lbs. So start at 40-50ft/lbs on the torque wrench. And hopefully you can break them loose before the torque wrench clicks. If they dont break loose, take it to the dealership if you are worried and have them change the themo for you. much above 50ft/lbs and you in the range of where you can shear off the bolt, especially if it has been weaked or rusted due to anti freeze. The torque wrench will keep you safe if it clicks befores the bolt break free, just go to dealership and them worry about. Then when you get home pull the bolts back out and properly apply anti-seize to them so in 24 months you dont have the same problem again. Bad news is the if bolts are really shot they can snap with less torque. Also just a suggestion rather then strain using a 12 inch rachet, use your toruque wrench assuming its a 24 inch model like most you will be able to apply a more consistent force on the bolts since your strenght is increased due to the 24 inch handle, you can more gently apply force to the bolts and break them free, just dont go gorillia on them.....use nice slow finesse. Good Luck
PB Blaster or other reputable penetrating oil is a better option than WD-40 (a lubricating oil). No slight intended against WD-40 but it is not the best choice in this case.
"4.6 02 Black GT" is 101% correct about using anti-seize and a decent torque wrench.
Good luck with the flush!
Chris
I know the military's rules don't usually apply to civilian life, or even make much sense, but we've always been told to never use torque wrenches to loosen anything.. furthermore, we're told the reason they have a reverse feature isn't for loosening, but for torquing reverse thread nuts/bolts.
With breaker bars, larger drive socket wrenches, etc.
If torque wrenches were designed to break stuff loose, wouldn't they call them "untorque wrenches" ?
