condition of distributor cap
just4bob50
504
Pa.
when i was working on my car yesterday I pulled my dist. cap for some clearance. On the terminals on the inside of the cap i saw a white residue where the rotor would pass. As i cleaned the terminals up i saw that the metal on the terminals was actually missing. there were obvious cresent shaped areas that looked as though the metal was burnt away. Last summer when i bought my crane HI-6S ign. system i replaced all the plug wires and cap & rotor. the cap and rotor were from autozone. after i put the cap back on, my car had a slight miss and the ign. sounded like it started to break up after 5000rpms. It did not do this before i cleaned the terminals.I was told that the crane throws too much spark for the cheap autozone cap & rotor to hold up to long term. If this is true I was going to order the MSD replacement cap and rotor. Also I have the original ign. module on my stock dist. and my car has over 100,000 miles on it. should that be replaced also and if so what part would work with my set up.
Just4.
I can't answer all your questions but thought I would share my experience with this stuff.
I ran the MSD ignition on my car for a couple of years. I used a Ford Cap and rotor and FRPP 9mm ignition wires. Yes, my cap terminals had that little groove where the rotor went wizzing by. Also got that white corrosion stuff too. The white corrosion is normal for the aluminum posts, just needs to be cleaned occasionally. A little dielectric grease on all the metal parts helps. Brass terminals are supposedly a help with the corrosion. I tried an expensive brass cap, can't remember the company, but didn't really find any difference. Instead of white corrosion it was black!
At one point I did actually develop a miss situation...and especially a dropout of ignition at higher rpms. Ford diagnosed it as a faulty ignition module. I even got in on a class action law suit and got my money returned to me. The TFI modules are easy to replace, and with your combo and mileage it sure wouldn't hurt. I would definitely go with a Ford or PA performance TFI. Don't go with a parts store TFI. I made that mistake and it didn't work well at all.
Good luck and let us know what you find out.
Ken
