- Oct 21, 2006
- 515
- 43
- 49
Below in bold is from jrichker
The following examples are only for naturally aspirated engines.
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle.
Example:
19/.5 = 38, 38 x 8 = 304
24/.5 = 48, 48 x 8 = 384
30/.5 = 60, 60 x 8 = 480
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85 (cheat on the math and use .588 instead of .5 and you don’t have to multiply the end result by.85)
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
I'm not sure if my fuel pressure is correct.
My engine is rated at 345 flywheel horse power.
I'm running 24 lb injectors at 39 psi.
Does that mean that at 85 percent duty cycle that my injectors are good for only 326.4 horse power?
Should I increase fuel presuure?
Is there an equation to figure the proper amount of fuel pressure to duty cycle for injector size?
My car is run mostly at WOT at the drag strip.
Am I running lean?
I thought that 39psi was correct, but now I'm not sure.
Thanks for the help
Example:
Am I running lean?
Thanks for the help
