confused
  • Thread starter Thread starter allen12432
  • Start date Start date Mar 3, 2010
allen12432
  • Mar 3, 2010
Ok so i have a small concern, I bought the stang i have now from this 50's something guy who said it had a 302 in it. Ok the car started out as a 4 banger and had an engine swap. i went yesterday to get now plugs and wires for it and got plugs for a 87 5.0 302, got back home and their to big go back so i took one back with me, the plugs i ended up getting were for a 289, ok theres half the problem a 289's firing order is 15426378, set the plugs and wires back up to that it didnt work, so i went and got on my alldata and got the firing order for a 302/351 which is 1-3-7-2-6-5-4-8. but got to looking even closer the the intake manifold has ford 289 stamped in to it. what the heck do i have ?
P
powershift46
366
NW IA
Mar 3, 2010
  • Mar 3, 2010
look at the block casting # near the starter to determine the decade, It will look something like this... D2AE-6015-AA, which translates this way.
All blocks are 6015
D would be the decade, B=50s, C=60s, D=70s, E=80s, F= 90s.
2 would be the year of that decade.
A would indicate the passenger car line, A being Fairlanes, but used in other bodies, etc.
E = engine
you can narrow it down from there once you have those numbers.
R
RatStang
544
  • Mar 3, 2010
Could very well be that you have a 302 that somone has tossed 289 heads and intake onto (was probably a deal of a lifetime).
allen12432
  • Mar 3, 2010
when you say a deal of a lifetime what do you mean? that a good or a bad thing?
P
powershift46
366
NW IA
Mar 3, 2010
  • Mar 3, 2010
he means "free"
rd
3,316
63
109
Ocean Springs MS
Mar 3, 2010
  • Mar 3, 2010
A 302 up through 81 will have the older 289 - 302 firing order. It did not change until the GT in 1982.
I have an orig 79 5.0 with the older firing order. My 82 has it also.
What determines the firing order is the cam, so you match the firing order to that of the cam. You can put either cam and firing order in any sbf block. Sparkplug sizes may also vary.
Intake manifolds also interchange from 260-289-302 engines, as well as heads and other stuff.
For example, I have a 68 block with a 78 crank and rods, 94 truck heads, 79 front dress, pan and flexplate, in an 82 body.
You most likely do have a flat tappet cam older style 302.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
