  • 1994 - 1995 Specific Tech
convertibles owners read.............
  • Thread starter Thread starter blackstanger95
  • Start date Start date Nov 30, 2004
First Prev 2 of 2
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
May 15, 2005
#21
  • May 15, 2005
  • #21
among the other things listed, alum rad, billet electric water pump, manual steering (a bitch for a DD tho), battery in trunk (more for wieght transfer, but thats the goal along with weight reduction), lightweight front brakes like Wilwoods, and some skinnies for track duty wouldn't hurt either...just some suggestions guys....my dad got 197 lbs off the front of his chevelle over the winter, and he used those things about along with a few other things that wouldn't apply to late model mustangs such as a 3lb fiberglass front bumper
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
May 16, 2005
#22
  • May 16, 2005
  • #22
How much of a difference at the track would say 3000 and 3300 pounds make?
Swarzkopf
973
Pittsburgh
May 16, 2005
#23
  • May 16, 2005
  • #23
215hp, 3300lbs- 14.48 at 94mph
215hp, 3000lbs- 14.02 at 97mph
From http://www.mustangworks.com/analyzer.html
Venom351R
4,548
41
98
MAINE
May 16, 2005
#24
  • May 16, 2005
  • #24
approx 3 tenth's 100LBS = 1 tenth.
M
mikeflys1
217
CT
May 16, 2005
#25
  • May 16, 2005
  • #25
The sound deadening stuff definately isnt 80 lbs. Maybe 15-25 tops throughout the whole car.
BOSTANG
27
Mesa AZ
May 16, 2005
#26
  • May 16, 2005
  • #26
Get rid of those heavy ass stock seats.
Swarzkopf
973
Pittsburgh
May 16, 2005
#27
  • May 16, 2005
  • #27
Agreed....I lost a TON of weight by going to my Summit racing seats.
CManT1914
3,172
Killeen, Texas
May 16, 2005
#28
  • May 16, 2005
  • #28
I don't know man, I read somewhere that a guy took out all his sound deadening material, and he had like 3.5 garbage bags full of it, and they weighed like 20 lbs a piece. When I took out my insulation pad under the rear seat, that thing was damn heavy just by itself.
R
Rossafeller
28
#29
  • May 22, 2005
  • #29
Convertible comment
Most likely you WOULD gain the biggest advantage by removing your sound detoner material. My 87 GT CONV weighs 4100, and i have removed my back seat and i may have been looking at losing about 6-7 pounds. My friend has a 96 GT and his car weighs over 4400, so im guessing that the mid 90's year models gained the extra weight with the sounds blocking material and all of the added safety equipment. I can say that if you do remove your back seat you wont really have to worry about it being TOO loud, because the carpet alone will muffle it alot; when my back was bare metal it was very loud, but once i carpeted it, it sounded the same as before.
CManT1914
3,172
Killeen, Texas
May 22, 2005
#30
  • May 22, 2005
  • #30
Your cars don't weigh that much. If you got that weight from the door sticker, that's maximum pulling weight, as in how much the car is able to pull safely fully loaded. Like with 4 passengers and luggage.
Killercanary
The car that set the bar.
Altoona, PA
May 22, 2005
#31
  • May 22, 2005
  • #31
Steven, where are you getting these numbers from? (meaning where are you weighing it at) I see NO WAY IN HELL those cars weigh >4100. Even with a iron headed dart block, no weight reduction, full tank of fuel, roll CAGE, subframes, AOD, etc I still don't see it getting into that weight range.
215what
154
NM
May 22, 2005
#32
  • May 22, 2005
  • #32
cut the metal under the palstic all that safety crap should save some good weight just leve the skin of the car
OrangeMustangGt
1,976
Cape Cod, MA
May 22, 2005
#33
  • May 22, 2005
  • #33
yeah you could remove both front fenders, the hood and the bumpers....
1EVIL88VERT
314
Dyess AFB, TX
May 22, 2005
#34
  • May 22, 2005
  • #34
no way in hell are those cars that heavy......did you take the kegs out of the back when you put them on the scales?
Don 95Vert
1,091
Delaware, OH
May 22, 2005
#35
  • May 22, 2005
  • #35
I'd guess that mine is probably one of the heavier ones out there - it weighs 3800 with me in it. Up 100# from a year and a half ago - I seem to be going in the opposite direction. But the Windsor block weighs 100+# more than the 302 and all the turbo crap is heavy too. I did move the battery to the trunk so it won't be quite as nose heavy. Plus I got rid of my skinnys up front - too scary on the street.
Don't go too crazy getting rid of the comfort features, just add more power
R
Rossafeller
28
#36
  • May 23, 2005
  • #36
Well, i stand corrected, because i was getting our weight from the door stickers where it says total curb weight. If thats not where you all get your weight from, then how do you get it, i wouldnt mind knowing how much my car weighed stock?
Killercanary
Altoona, PA
May 23, 2005
#37
  • May 23, 2005
  • #37
No, you can NOT use that weight. We either weight our cars at the track on its scales or any place that can weigh a vehicle like a place that sells stone, coal, etc.
CManT1914
3,172
Killeen, Texas
May 23, 2005
#38
  • May 23, 2005
  • #38
Like Paul said, if your track has a scale (mine doesn't ) then you can weigh it there. Otherwise, you might try the city dump.
First Prev 2 of 2
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
D
Rust on Window Belt
  • DuluthFoxbody
  • Nov 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 4, 2026
DuluthFoxbody
D
