Coolant Light Issues....what else is new?
Unreal281
98
Hey guys....just to let all of you know....that stupid problem that i had was a simple PCV. Its all solved and the idle is back to normal!!!!:nice:
Now....i'm sick of seeing this stupid coolant light on....just one simple question....is there any way to disable it??? disconnect it? anything?????
thanx guys.....
How about the stupid seat belt chime????
:SNSign:
Yea.....the coolant level and everything is fine...actually just had it flushed and checked out......just the stupid light wont go off....my question to you guys on here would be:
How do i disable....or disconnect the light? i know this is an all too common problem....i've seen plenty of street racing videos and whatnot with GT's having the light on......how do i just disable the LIGHT????
Also......what do i have to do to disconnect the seatbelt chime? I dont' have the original owners manual.....
thanx
thanx
I've heard before that the coolant level sensor gets stuck (in the resivour) and that ends up being the case when the light goes on
Ok.....i completely understand that.....but the way i drive the car it probably will get lodged into the corner of the overflow again or something.....yada yada....i just wanna know how to disconnect the light so it can be on all it wants....."which it probably will be" but i wont have to see it.....i check my coolant and fluid levels ALL the time so it really doesn't matter to me....just sick of seeing that stupid yellow light...
Also....ANYONE know how to get rid of the seatbelt chime? I don't have a stupid owners manual.....
you have to remove the
headlight knob,
cluster bezel,
unscrew the retaining speedo cluster bolts and remove the cluster,
disconnect the 2 main harness on the cluster and you'll see the lights sticking out
find the one for the coolant light and twist it off
keep it in a box or something :cool:
i just snapped a pic for you. opposite side, far left, it'll say Lo Cool :cool: lol
Dude....thank you SOOOO much!!!! Thats a kick ass description of the situation....thanx so much for taking the time to do that bro.....I'll get on that then and remove the peice.....you rule
So, can anyone else get in their owner's manual or something for me and check the description as to shut off the seatbelt chime/light??? thanx guys.....
Tomustang.....THANX DUDE
:SNSign:
I don't know if this will work on the 1996-2004 Mustang, but the Fox body coolant overflow tank has metal electrodes at the bottom of the sensor.
Remove the sensor, and soak the electrodes in vinegar for 2 minutes, then take a small piece of 1500 grit sandpaper, or a nail file, and scrub off all the oxidized looking white powdery stuff that builds up on the electrodes.
Finish with some rubbing alcohol, and the tank will be able to sense the water in the tank, now that the electrodes are clean.
Takes 5 minutes, and shuts off the light.:nice:
