Coolant Overflow Tank.
94GTCoupe
1,412
92
79
CA
is the overflow tank from the 94-95 v6 the same as our 94-95 GT's?
mine has a hole in it where it attaches to the CCRM bracket.plus it dont look too good:notnice:
saw a couple V6 overflow tank's at the JY in good condition,i'll pick one up if they are the same.
if this is tech,please move me.thank's :)
They are not exactly the same. The tank will fit in the same place, but the V6 tank does not have the notches in the top to fit the Low Coolant sensor - it only has a plastic cap. Of course, you can do like I did in my Cobra conversion; you can notch the plastic neck of the V6 tank to match the GT, and it will work perfectly. It's a bit of work, depends on how perfect you want it to be. But it will work.
thanks guys.1/2 off at the jy this weekend.i may get one,it will only cost a couple dollars.
Posted via Mobile Device
