Coolant passage on intake.
2BADSTANGS
385
Colorado
This is probably a stupid quuestion but here goes. Why did the factoy run the coolant through the intake by the throttle body? I have had a cobra intake on my '93 for a while now and when I put it on, I just connected the hoses together. What are the hoses attached to? Can you just cap off where they are connected or is the best route to do as I did? Thanks!
The hoses originally connected to the EGR spacer. There have been lots of disagreement on what Fords intent was with the coolant hoses. Some say that is was to keep the TB from icing up in cold weather and others think that it was to keep the EGR spacer cooler since it has hot exhaust gases flowing through it. One of the early tricks was to bypass or plug the coolant lines going to the TB based on the assumption that it would keep the intake charge cooler. Whether that works or not I can't say. My thoughts are that the it is there to keep the EGR spacer cooler and I have never disconnected them on my cars. Exhaust gases are hotter than 180* coolant so I keep them connected. Some will agree and some will disagree. The argument has been around for a long time. If the cobra intake doesn't have spots to connect them then you could block them off at the back of the intake and the heater tube or just connect them together and route them out of he way.
Reactions: biminiblue92
