when i got my car 5 or 6 years ago, it had always run at about 1/4 of the way up the factory gauge. a couple years ago i decided to change the water temp sensor, and when i did, it started working again, and fluctuated. usually ran about halfway up the gauge.
this is a stock fox (motor wise) with the fan clutch still. ive had my coolant flushed 3 or 4 times since ive owned it, even added water wetter. its not leaking much coolant, i have to add about a half a resovior full every year or so if that, i dont see it leaking anywhere, so it must be burning it.
as of recently on the stock gauge, the car has been running close to the halfway point on the factory gauge, and when i get in stop and go traffic with the ac on it will get up to the halfway point, sometimes a little above it.
a few days ago my air conditioning stopped blowing cold, so tonight i fixed the leak (o ring in the retrofit valve to 134a) and recharged it and the ac was blowing cold. this was at night, with the sun down. when i drove home i noticed that it was running a little above the middle of the gauge, and when i was almost home it was 3/4s of the way up the gauge. i turned on the heat full stuff and got it back down a little.
i just replaced the fan clutch again a few weeks ago with an imperial brand one from work (advance auto), and seems to have good resistance to it. when the car is hot and the motor is off, i can spin it, and it will turn another 1/8th of a turn or so on its own.
i know its the factory gauge and all, but it must do something. somewhere it must be sensing that something is hot. summer is almost over and the car will sit all winter, but im trying to figure out what can cause this if the gauge is reading right. im going to try to find a shop tomorrow that has a point and shoot temp gun to try to see if its actually running hot or not.
any ideas?
if you coolant is clean and your fan clutch has decent resistance, what else can cause higher coolant temps? water pump not circulating fast enough? i would say sticking thermostat, but its pretty consistent so far.
any ideas?
