  • 1994 - 1995 Specific Tech
Coolant Temperature
  • Thread starter Thread starter Guero
  • Start date Start date Jul 16, 2007
Guero
2,148
Jul 16, 2007
  • Jul 16, 2007
On my autometer gauge it reads 220. I also have a Mr. Gasket radiator cap with a thermometer. And it doesn't read higher than 180. So is my autometer gauge of???
Blackened302
1,439
South TX
Jul 16, 2007
  • Jul 16, 2007
can't you check it w/ your RT?
Guero
2,148
Jul 16, 2007
  • Jul 16, 2007
Yeah I just did, it said 232. God damn it. now its overheating!!!!!!!!!!!!
Blackened302
1,439
South TX
Jul 16, 2007
  • Jul 16, 2007
crap, man.
don't you have a fluidyne?
what thermostat are you running? what type of coolant/water mix?
are your fans turning on?
Guero
2,148
Jul 16, 2007
  • Jul 16, 2007
I got the summit radiotor and a 160 mr gasket thermostat and yes the fans turn on. Im running nothing but water and 2 bottles of watterwetter. The car has been getting hot, but not that bad. Maybe the timing issue heats it up a couple of degrees to.
94-302-vert
1,947
NE CT
Jul 16, 2007
  • Jul 16, 2007
Timing can definitely cause a lot of heat...
I would suspect a difference between the radiator cap and the T-stat housing...
steede302
75
jacksonville fl
Jul 16, 2007
  • Jul 16, 2007
There should be a difference between the rad cap temp and the t-stat housing temp. How much timing are you running?
Possible water pump going bad( maybe).
HISSIN50
34
129
Jul 16, 2007
  • Jul 16, 2007
I agree that there is a relatively wide array of readings throughout the system.
We use the ECT and stock sending unit location by convention (so one guy's not reading temps from one place and another is reading them elsewhere).
220* is a little warm but not out of the question Guero. I've found that almost on the nose, while going slow or stopped, the stock fan keeps the coolant about 100*F higher than the ambient temps (when it's 100* or warmer outside). So if it's 110* up there, 210-210* would not be horrid. It should cool down a bit once you get up to about 45 mph of easy cruising and low RPM (keep the tach under 2000 RPM).
Running water and WW is fine. Make REAL sure your cap is holding pressure. Otherwise, you could get into trouble.
Does it do better while idling or better while driving easy at 45 mph+ ?
blksn955.o
3,263
st.louis mo 314
Jul 16, 2007
  • Jul 16, 2007
IMHO ditch the 160 stat and get a 190...MAYBE a 180. I run a 190 with the fan settings from the faq section on what to set them too. On a 90-95* day it does not go higher than 192-194. Anything less than 90* out of the sun and it sits just over 180. No matter how much I get on it.
Both by my logs and the autometer guage I have.
I had a problem with the fans not in sync with the stat. Messing around I ran a tune with stock fan settings and one exactly the same with the 190 settings. The stock fan settings was at least 5* hotter within a min. or two and would start climbing 10* hotter. I would flip to the diff. fan setting tune and the temps would drop almost instantly.
I run the stock rad. 50/50 mix and it gets HOT and MUGGY in the STL.
I
igotyofire
774
Southern California
Jul 16, 2007
#10
  • Jul 16, 2007
  • #10
i coulda sworn i heard people say the 160degree thermastat can cause cars to run warm and that it was too low. seemed like most people recommended the 180 one.
Guero
2,148
Jul 16, 2007
#11
  • Jul 16, 2007
  • #11
NO
Methodical
1,192
11
59
Clinton, MD
Jul 16, 2007
#12
  • Jul 16, 2007
  • #12
HISSIN50 said:
..Running water and WW is fine. Make REAL sure your cap is holding pressure. Otherwise, you could get into trouble.
Wouldn't running water without antifreeze lower the boiling point, which could lead to overheating . Personally, I'd be a little nervous just running water without antifreeze. But I know there's more than 1 way to skin a cat.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 16, 2007
#13
  • Jul 16, 2007
  • #13
Always remember we got Aluminum parts
You want those properties in Coolant that keeps the corrosion down or
your nice shiny parts will go to poo poo
Honestly ... our pcm fan temps are so high ............
Seems like a lot of the other stuff is not gonna be all that effective at
getting the temps down
Grady
HISSIN50
34
129
Jul 16, 2007
#14
  • Jul 16, 2007
  • #14
Water Wetter inhibits corrosion. It's fairly common around here to run distilled water and a couple bottles of WW in the summer. Then guys go back to a conventional mix in less hot seasons (we're on a roll of 33+ straight days of triple-digit temps). It's not something I like to do (I feel that a system should cool properly at 50/50 mix) but I don't have an issue with it either (just speaking personally. We deal with the heat however we can). I do think a bottle of rust inhibitor/lube would be a good idea (you can get them for a few bucks).
The thing with coolant vs water: Water rejects heat about 2.5 times more efficiently than E/G coolant. That's huge. We just need the coolant for the reasons you all mentioned (rust inhibition, lubrication and freeze protection). It is remarkable how *little* antifreeze does to raise the boiling point. The pressure in the system is the main factor regarding an artificially high boiling point.
Now knowing that water transfers heat so much better than coolant, any displacement of water in favor of coolant is going to allow the car to run a little hotter than it would have had the water not been displaced. That slight raise in the boiling point from the coolant becomes moot.
As far as freeze protection, coolant coolant coolant. That's where it shines. And because it doesnt transfer as efficiently, it doesnt take as long for the car to warm up (read get you some heat inside the car).
Just MHO on this stuff.
BTW Guero, you answered no to a question that wasn't yes or no. I was wondering if your car cooled down once you started moving.
Guero
2,148
Jul 17, 2007
#15
  • Jul 17, 2007
  • #15
I ment no it doesn't. It stays at 210 and wont cool any further
HISSIN50
34
129
Jul 17, 2007
#16
  • Jul 17, 2007
  • #16
You should cool better at speed than while idling - it should not be the same, unless there's a limiting factor in the system.
I still gotta say though that 210 isn't outrageous considering your mods man.
If it's not hard to do, adding a little fuel might help. It's something I'd consider if you're not running real fat already (Grady and others can comment about whether they think this is a worthwhile thing to consider).
Hey, is your timing thing all fixed? Did Urban's puter take care of it? Is timing spot on again?
YES
(There, I answered for you).
Guero
2,148
Jul 17, 2007
#17
  • Jul 17, 2007
  • #17
I been struggling with the computer for 2 days and I cant take it of. Honestly its been getting hot for a while, but i guess with triple digit temps it made it worst. Plus i know for a fact it didn't get hot when everything was working properly.
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
A
ECT sensor wires gone?? HELP
  • archer886
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 8, 2025
Mustang5L5
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
