Coolant?
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Oct 2, 2004
MUSTANGJOE
Silver Stanger
1,644
17
59
Oct 2, 2004
  • Oct 2, 2004
I woke up this morning and started the stang and saw the low coolant light on! My car used to do that cause of a leak in the radiator but I fixed that. Were does this coolant go? I've always had trouble with the coolant on this car. My cap for the reserve tank is broken and is barley caped right, could that be the problem? Thanks
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Oct 2, 2004
  • Oct 2, 2004
my over flow hose sometimes will dribble from the bottom of the reserve tank. and will be low.
88stangmangt
2,332
Stafford,VA
Oct 2, 2004
  • Oct 2, 2004
looks for wet spots dirt covered.........if you cant find any....and dont want to think bad (I.E leaking head gasket)buy some black light dye.............poor it in your rad.....................drive it for a couple hundred miles then take a black light stick to it.....................other wise the idiot lights arnt 100% mine went off none stop my system never took any extra or leaked any...............
CRASH7772
401
NH
Oct 2, 2004
  • Oct 2, 2004
What kind of mix do you run? Could be the water evaporating over time if it's a higher water mix than coolant. Mine does the same thing but it doesn't leak. Just mentioning that because alot of people check it and see it's a little low and just add water ( I do this at times myself) and some people just run a higher water mix. I used more coolant than water and seemed to fix the light coming on.
MUSTANGJOE
Silver Stanger
1,644
17
59
Oct 3, 2004
  • Oct 3, 2004
I usuall do use more coolant than water. I think im goona do another coolant flush and add the right mix. Its 50-50 right,,water and coolant?
CRASH7772
401
NH
Oct 3, 2004
  • Oct 3, 2004
Sounds like a good start. They have testers that will tell you how good your coolant is. If it hasn't been changed in a while you might be due anyways.
Whytry91
321
Morrisville, NC
Oct 3, 2004
  • Oct 3, 2004
If you are actually losing water, you may want to check under your water pump. there is a thing called a weep hole (not sure that's how it's spelled) my car exhibited the same thing for months and I could never figure it out. Basically in my was what was happening was, there was a tiny bit of water coming out of it while I was driving, but when I would stop and check it out there would be nothing, the water would evaporate because it was such a small amount, over time the leak got worse which is when I finally found the it. Just a suggestion and good luck
stingeragent
33
Lubbock, Tx
Nov 23, 2004
  • Nov 23, 2004
What coolant to use on stock radiator
Hi, My low coolant light came on today and I manually checked and it is low. I was about to put in a gallon of water when I noticed that thing that says your engine needs a special coolant" ford and some number", then it says only use water in case of emergency. Is that true and if so what am I supposed to use and where can I get it?
C
crunchie12268
599
Manhattan, KS
Nov 23, 2004
  • Nov 23, 2004
Mine did this one time because my peacock wasn't in all the way, and it was slowy dripping out.
five_o_stang
92
Georgia
Nov 23, 2004
#10
  • Nov 23, 2004
  • #10
My low coolant light kept coming on...even when I wasn't losing coolant...
For me it was the low level sensor...(that long tube coming down of the cap of the resevoir)...yeah...only way to replace that one new was $75 from Ford...screw that...I just disconnected my sensor and I check my fluid regularly...no more light...YAY
C
crunchie12268
599
Manhattan, KS
Nov 23, 2004
#11
  • Nov 23, 2004
  • #11
Yeah no joke, I lost mine at the carwash when I did my intake swap, it was around 70 bucks for a new one.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Nov 23, 2004
#12
  • Nov 23, 2004
  • #12
The sensors can sometimes just be cleaned off from what I hear. I've never had one -- always had older cars and LX's, but it sounds like a better place to start than shelling out $75!
HISSIN50
34
129
Nov 23, 2004
#13
  • Nov 23, 2004
  • #13
i have heard that once you find the hole you can put a 160* thermostat in the hole and the system will run great.
Adam is right - one can clean the sensor up. some guys (if they know they are up to capacity and it is a sensor fault) will rewire it so the light is inoperable.
one can get dye to put in the system to check for leaks.
good luck.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Nov 23, 2004
#14
  • Nov 23, 2004
  • #14
Yes I heard that no matter what cooling problem you have use a 160* tstat and all will be fine. It worked for one car it will work for EVERY car.
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
