Cooling issue
  • Thread starter Thread starter 86bluecobra
  • Start date Start date Sep 2, 2006
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 2, 2006
  • Sep 2, 2006
Ok here is what is going on. The other day i was idling at a stop light for about a min. I noticed my temp was going up it hit 200. No real big deal. It does that sometimes on hot days. Then when i get to driving again its back to 180. The next day i switched on the electric fan so it wouldn't happen again. To my surprise it did climb again to 210. This is wierd because my car can idle for hours with the electric fan on and stay at 180 degrees. The next day i take my car for a spin i notice the temp gauge jumping from 200 to 220 then back to 210 and all over but in the 200 degree plus temp. When i got home i checked under the hood. Thought maybe the rad cap was off. I felt the top rad hose and it was cold. Would it be safe to assume that the thermostat is going? The rad was also not hot because the fan did not switch on by itself. was thinking bout swapping out the thermostat today. My temp gauge is a ford racing unit.
HISSIN50
34
129
Sep 2, 2006
  • Sep 2, 2006
Your line of thinking sounds good to me.
I like your idea for a stat swap in any case - it sounds like it's not a brand new unit. I like the Mr Gasket line, but that's a personal choice.
Good luck.
RYC CUKR
1,437
Orlando
Sep 2, 2006
  • Sep 2, 2006
Sounds like a T stat. I had issues kinda like that in my 93 and put a Mr Gasket balanced stat, at Hissin's suggestion, in and problem solved.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 9, 2006
  • Sep 9, 2006
Changed the T-stat and she is good as new. Since my car has a tendance to run a little on the hotter side i drilled 2 5/64th's holes in the t-stat.
HISSIN50
34
129
Sep 9, 2006
  • Sep 9, 2006
Glad to hear it's better. Nice work deciding upon a plan and having it work!
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
