cooling problem...
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jan 30, 2008
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 30, 2008
  • Jan 30, 2008
ok i got my car all back together.
it will start up and idle fine. i have the radiator cap off. i fill up the radiator and wait for the t-stat to open. the temp gauge wont read a thing for like 5- 10 mins.
then ALL OF A SUDDEN it rised from nothing to around 225 degrees within like 5 secs.... settles there and then slowly rises.
then i shut the car off and coolant PUKES out of the radiator.
i feel the upper rad hose and its cold. no coolant has passed though it at all. like the t-stat didnt open.
but if thats the case why wouldnt the temp guage slowly rise as it warms up. if there is coolant circulating in the engine and if the t-stat is closed it outa slowly heat up and then finally open the t-stat.
mine just stays super cool and doesnt register on my gauge and then all of a sudden jumps to 200+ in like 5 secs.
i am pretty sure the t-stat is installed the correct way. i am going to take it off later and check for sure. maybe it could be stuck. i just bought it the other day maybe i got a crappy one by bad luck. also thought it could be an air bubble. but i think there is a burp hole on the thermostat.
any more ideas??
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jan 30, 2008
  • Jan 30, 2008
Where did you get the thermostat? I've crappy chain store t stats that didn't work when brand new.
I like the mr. gasket, it's only like $10
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jan 30, 2008
  • Jan 30, 2008
its a cheapie 3 dollar one. from oreilys
i am thinking its the t-stat. the temp sending unit for my gauge is reading. and if its getting to that then it should be hitting the t-stat, its less than a foot away from there and on the same level.
but its still strange how the gauge acts. it sits at the bottom not even reading and then all of a sudden hot coolant gets to it and it jumps up fast up to over 200+ degrees.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 30, 2008
  • Jan 30, 2008
Sounds like the t-stat is installed backwards. Remember, pointy end towards the hose, spring end towards the engine.
BigHairyMonkey
411
Houston (Bellaire) TX
Jan 30, 2008
  • Jan 30, 2008
^ im with wythors. I did the same stupid mistake when i installed my mr gasket t-stat and couldnt figure out why i was overheating..
ttop88
42
indiana
Jan 31, 2008
  • Jan 31, 2008
T-stat assbackwards will do that. A huge air pocket will too tho.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jan 31, 2008
  • Jan 31, 2008
i am going to check when i get a chance, its been snowing all day so its all messy lol.
strtrcr50
Previously from Dirty Jerzey exit 7a
Jan 31, 2008
  • Jan 31, 2008
Sounds like an air bubble to me. Why not try jacking the front of the car up when you do that?
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 31, 2008
  • Jan 31, 2008
let it puke it will get all the air out leave it run and keep a hose handy, just watch your gauge!
monte87
876
18
49
new york
Feb 1, 2008
#10
  • Feb 1, 2008
  • #10
Dude-
Do not use cheap T-stats, Use Mr. Gasket its truly balanced tested and hi-perf and opens up on the designated rated like clockwork. screw all others. Thats my opinion. i always used them and never ever have a problem.
Ant
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Feb 1, 2008
#11
  • Feb 1, 2008
  • #11
well i gave her one more try before i took out the t-stat. i jacked the front end up and let her run. she puked up a little bit of water and then the level dropped and the t-stat opened. there was just a huge air pocket in the engine.
its full of coolant now and cools great!!
monte87
876
18
49
new york
Feb 1, 2008
#12
  • Feb 1, 2008
  • #12
FYI- Mr. Gasket's come with bleeder hole, that does all that for you without having to jack anything up. Just for future reference. You take the cap off, let it run and watch the bubbles, when the therm opens, slap the cap on-Easy as that. Mr. Gaskets are the best in my book!
Later Ant
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
