correct firing order
jay the oger
Hello everyone this should be easy for me yet i keep second guessing my self I build a 69 coup for sons first car and got engine that owner said had a dead hole witch it didn't but anyway long story short bottom end is a 302 and has old cast heads off a 351w cam is a 280h stamped on the end witch cam with unit witch firing order is the correct one or gets the most out of engine .
280 H is a great cam ,slightly rough idle but great power .
Now ,ford has 2 different firing orders for this cam ,it interchanges with the 351 and that firing order is different
The 351 order is 13726548
The 289 302 is 15426378 .
They both work in both motors but you have to know the firing order of the cam in use . Simply try both fireing orders if you do not know what cam it is ,you will know if it is the wrong fire order
Thanks for the info went ahead and tryed to run it on the 351 order but wouldn't even start changed it back and it fired right up thanks again
