correct injector for fox body
Idan24
12
colombia
Hello people, I have a Foxbo 1980 with Engine swap 5.0 ho 1989 EFI MAF, engine bearing performance, oil pump performan, TRW3096 +0.40 Pistons, Cam X303 ford racing, Oem Roller, lift, Lower, and Upper intake Holley Sytemax II, Tb 75mm, Air Filter K&N 75mm, MAF 75mm 19lb, Oem inyector 19b. But I have diferents problem.
the first ist, My fox allwaays its extremly rich, i want buy new Inyectors, but I don't know which one to buy 19lb or 24 lb, recently i buy a ebay 8 inyecteors 19b 60 usd, but the problem remained the same.
my fox went i stop after 3 min in idle, the rpm it is not constant.
what its my ideal rpm idel with my x303 cam.
what its my ideal 1/4 mile time on drag sliks wheels
Your must be the same as your MAF is calibrated for.
If it is running rich, it needs checked for codes, the O2 sensors checked out, vac leaks chased down. You might as well go systematically through the surging idle checklist and find out the overall health of the system.
Reactions: 1 user
Some ebay injectors are junk, I just swapped out a junk set for some 19's out of my engine.
How limited is the speed shops or machine shops in Columbia?
You may be able to send them off to get flow tested, or just buy new, 24lb injectors won't hurt you as long as you get a matching MAF.
Remember, do one step at a time, too many times too many things get changed and it makes repairing the problem harder.
Give us a pic of that engine, and the rest of the car too. Let's see what you got there.
WHat heads? I didn't see them listed. If stock, 19# should be plenty. 19# is the original injector size. Xcam is pretty aggressive with stock heads and in general for a street car.
Go through post #3 and start with dumping the codes. This is a 1980 bodied car with a 1989 engine? What wiring was used?
Currently, I have all the wiring of a FOX, since I also Swap instrument panel 1993.
My heads, E7PA ported
MAF sensor F5UF 12B579 -BA
OEM 19LB injectors
Codes I only have EGR, and Pump (but this is not important because of the external pump circuit)
That MAF sensor is not correct for your application. It's an 95+ F150 5.0 MAF. It would cause your issues as the transfer curve is all wrong.
Can you take a picture of the electronics on top and the housing?
The correct, stock, 55mm MAF is part number:
E9ZF-12B579-AA, or F1ZZ-12B579-A
You can also run one of the below 70mm MAFS. These are the only part numbers you can use
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Those are all bolt-on flange style MAF's. You can either buy an adapter off Ebay for $10 to use with the stock airbox, or buy a 91-93 T-bird/Cougar MAF and use the housing only with the F2VF electronics listed above.
I understand if that might be a tad bit confusing
  • Useful
  • Informative
Reactions: 2 users
