Couple questions while doing my new shortblock.
mo_dingo
Aug 26, 2003
3,031
Tucson, AZ
I have three questions.
First, is it normal for stud mount FRPP rockers to be at different heights? Meaning that some caps are screwed down further down the stud than others. This is obvious when you look at the depth of the alan stop screw inside the cap.
Second, what thread is the hole at the back left of the intake? My track heat lower has a hole in the back that didn't come with a plug to install. Is this where the ect sensor goes if I had a fox?
Thirdly, when you install new lifters, there is a purge hole in each of the lifters. Should it point towards the cam, or the outside of the block? Does it matter?
Scott
1 I have Scorpions but don't remembering seeing differences
2 No clue
3 I was the only one to go in my motor since Ford put it together. I found some pointing up ... some down. I put them all back pointing up
Grady
