Update:
Also my 2000th post
Well I got the gasket in today...so we were ready to install it all...
I blew off the intake real well of all the aluminum shavings and we bolted up the intake...and we found out why I cracked the ear off the intake...the valve where the two pcv hoses connect on to each other (from front of the engine) that is on the right back underside of the intake was hitting the taller valve covers which didn't allow the upper intake to sit flush which is why it broke off so easy...so we had an easy fix: We just pulled the intake off (we definatly checked this time) and screwed in that little two-way valve in more and it gave us the clearance so we bolted everything back down and went to start it...worried about that previous "shreak" noise...
It started right up and very nicely
It seems to have more pep into it...I changed the rotor, cap, plugs, plug wires, readjusted valves, new valve covers to stop little oil leak, new pcv valve, cleaned the IAC and TB...so I guess that was good for something...
I let the car idle for about a minute or two (let some of the "smoke" off the new antiseize come off) and shut it down...
Usually my car doesn't want to rev when cold...it would have a delayed reaction from the gas pedal to the actual engine...but after a minute of idle...it revved like it was fully warm...
Now all this could be in my head but it all ended up good...I didn't test drive it because when we shut the car off we were greeted with more good news...
We put the car in 5th gear (as I thought to do and as Michael suggested) but the guy with me said to put it in second gear...and with some hard pulls after a couple trys it broke loose and we got the balancer off...
Now we got to get it on tomorrow...I know by hand we can't get the new one to even engage on the keyway? So I guess I'm going to heat it up in the oven and see if it will go further? Any tips...
Thanks for all the suggestions...
