ok, i installed a crane 2031 cam kit along with some ported e7's and reused my stock lifters.
when i tried to install my crane 1.7's, the rockers on the intake valves are fine. on the exhaust, the pushrods are too short. i cant get to zero lash. i can rock the rocker back and forth.
i tried putting on my stock rockers. 1.6's. turned the motor over till the exhaust valve opened and closed, then the intake valve opened and closed. right after it closed, i was on the base circle. i tightened the bolt till there was a slight drag on the push rod. then i torqued the bolts to 20 ft lbs. and got 1/4 to 3/4 on both intakes and exhaust.
after all the rockers were installed i noticed that i can push the plunger down in the lifter a little on half the rockers and the others are solid. this is with the valves closed.
is there something wrong here.
i'm getting really afraid about this stuff now and have that sick feeling in my stomach that something is wrong.
can anybody help me here?
