- Dec 13, 2009
- 40
- 0
- 0
68 mustang 289 bored .030 over comp cams 294s cam, lifters, springs, 10.5:1 compression, flowtech headers, 2 1/4 dual turbo mufflers.
now that you know the settup here is the issue.. i rev no higher that 6500 i drive somewhat aggressive but know how to take care of my car and dont abuse it. last night i got home and my dipstick was popped up about 3-4 inches and oil was on the bottom side of the hood. also i have 2 breather caps.... NO PCV HOOKED UP. i dont want to run a pcv if i dont have to. i understand that my crankcase pressure is way too much and this scares me. oil leaks from the breathers as well.
i just put a new breather on driverside valve cover because it was saturated with oil and wasnt useful.
now i need suggestions on what kind of evacuation system to use? they offer systems that weld to the exaust pipe BUT those are stricktly race only.
i could run a pcv but i dont like the idea of pumping smoke into my engine also the lose of carb suction.
i was also thinking just big breather tubes into a catch can but i dont know if that would work or be sufficient..
Please guys if you have had similar problems or know what to do i am open to all suggestions. thank you so much.
