HISSIN50 said:EGR being disconnected [without a tune] can result in part-throttle ping. But disconnecting it is NOT a way to get rid of pinging (just the opposite).
I gotcha.legalize420 said:right, mine pinged when it WAS deleted.
HISSIN50 said:I gotcha.I interpreted it the other way around.
My two cents. Pinging is a very high pitched (to my ears, which have listened to too much loud motorcycle exhaust with no helmet) noise. It does sound like the 'marbles rattling in a jar' - a hallow sound.R.J. said:I think I have the same problem and have had this problem for a while. Is a "metallic sputter" a good way to describe pinging? I have not narrowed it down to a speed, gear or rpm. If I'm on the highway doing 65 and start going up a hill, when I give it more gas (1/4 throttle +) to maintain speed, I get the noise and the car really doesn’t want to speed up. Under that kind of load it tends to happen with less throttle, but if I do a hard pull through 2nd and 3rd, I get the same noise at about 1/2 throttle+. Pinging?
HISSIN50 said:My two cents. Pinging is a very high pitched (to my ears, which have listened to too much loud motorcycle exhaust with no helmet) noise. It does sound like the 'marbles rattling in a jar' - a hallow sound.
Grady can tell you a lot more about the actual dynamic going on with the computer, But I notice that (I think) I have too much timing and too little fuel with light throttle input. If I stand on it more when I hear pinging (counterintuitive, if you ask me), it must richen up a bit and it helps. And being in a higher gear (5th, for example) reduces your mechanical advantage, which can cause pinging. Even lugging in a lower gear (like using 3rd when second should be used, esp if going uphill) can cause pinging. Mech advantage (the lack-there-of) again.
I will add that I have heard exhaust noises (leaks or bad smog pump) that can resonate in situations just like you describe. Others will help a lot more.
Good luck R.J.
final5-0 said:I agree with JT about how other things you may hear can make you think you hear the ping thing.![]()
I had one of those brick thingys in a cat come loose once that kinda sounded like ping.
Ping can cause damage![]()
Even all the more so if you got soft Aluminum heads![]()
If you even suspect you got it .......................
Try the following ... if the noise goes away ... you did indeed have it
1) Up the octane count at the pump
2) Dial back the spark a good bit
3) Do both 1 & 2
Grady
