  • SN95 4.6L Mustang Tech
Creative minds needed for a suggestion
  • Thread starter Thread starter hotstang_46
  • Start date Start date Dec 6, 2007
hotstang_46
481
Charlotte NC
Dec 6, 2007
  • Dec 6, 2007
What can I shim one of my rear shocks with to bring bring her up 1/3-1/2inch without impacting the performance that spring/ride.
I've seen the subject come up alot on here but never really seen any cures. The car sits low on one rear side ever since I put on my vogtlands. FYI...I'm not running any isolators....I'd probably just throw one back on that spring but I threw them away. Besides, wouldn't I notice when riding in the car that the corner with the isolator acted slightly different?
The best I've thought of so far is making something that looks like an isolator by taking a dremel to some hockey pucks......with my thought being they are stiff enough that they won't flex or move.
RandyStinchcomb
1,159
Randallstown, Md
Dec 6, 2007
  • Dec 6, 2007
I would NOT mess wth the shocks as reducing there travel, even a little bit will hurt the ride....I'd suggest putting the spring rubber back in place.
tiptone
37
  • Dec 6, 2007
First I would check to make sure the pigtails are seated properly on both sides. Assuming they are, just buy a new set of isolators and throw one in on the low side.
J
jprovence
195
Albany, OR
Dec 6, 2007
  • Dec 6, 2007
shimming the shocks will not raise to vehicle, just mess them up. try the isolators
Thundermouse
168
Decatur, GA
Dec 6, 2007
  • Dec 6, 2007
If you are that worried about cornering performance to rule out putting an isolator on only one side, you will be doing far more damage by trying to wedge something in between spring coils (I think that is what you are describing with the hockey). Remember, by putting something solid between coils, the spring is effectively losing coils and it gains spring rate; you really don't want different spring rates between sides of the car, especially on a rear suspension thats designed poorly from the get-go.
If you re-check the pigtails and they are fine, just get Adjustable height LCAs.
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 6, 2007
  • Dec 6, 2007
put the iso. on that side
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 6, 2007
  • Dec 6, 2007
i think summit sells spacers for the spring pearch
you could also get adjustable control arms
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
Stiffer front springs writeup from the old .net site
  • LILCBRA
  • Oct 24, 2022
2K
1974 - 1978 Mustang II Talk & Tech Oct 29, 2022
Enzio
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3 4
6K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:36 PM
ctandc
C
