Crushed oil pan
02SaleenS281
Well I was jacking my car up from the front, and the jack slipped from the spot I was jacking on and the car landed right on the oil pan. So I lowered the car, hoping maybe it would be ok cause the dent didn't look too bad, started the car and it sounds like the crank is smacking the oil pan or the oil pickup tube, it sounds sick. Anyone know the easiest way to get that pan out??? It's a '02 Saleen S281
ouch. Shouldn't be hard to drop the pan though. Can't remember what the bottom of my stang looks like at the moment, but i'm pretty sure the pan is accessable. The swaybar might be in the way, but i think just draining the oil and removing all the bolts around the pan will do it. :shrug:
How you didn't damage the crank counter-weights or anything like that
i'm almost positive you have to suspend motor, and drop K member to access all the bolts on oil pan. While your at it, it'll be excellent time to do header swap too
This is another one of those thing in our car, like headers.
Although, not difficult, its time consuming...
i agree with mity on this you might as well drop the K-member and support the motor form the top now you can install headers just like mity mentioned
