Situation - 68 Mustang: a/c hoses provided with Custom Auto Air perfect fit a/c system that connect to the condensor and dryer do not fit around the BeCool radiator (wider than stock). Local hose and auto a/c shops are not able to fabricate custom line. Custom Auto Air said that I was on my own and that didn't need the wider radiator - too late now.
Question - While most of the a/c system uses o-ring connectors, the condensor and dryer fittings are flare. I've been unable to locate the specifications on these flare fittings. Are they SAE 45, AN 37, something else? I'm thinking of using aeroquip fittings and hose to solve the problem.
Thanks,
Kent
Thanks,
Kent
