Cutting out Cats
bryan0
175
Bethel, CT
Has anyone removed the two far-back cats on their stock H-pipe? My co-worker (who has tons of experience with stangs) suggested the idea to me. The only problems I have with it are, will I need to get the MIL eliminators? and would I still pass emissions?
I would chop out the cats and replace them with a metal sleeve to connect the two pieces of the pipe.
You shouldn't need MIL's. As for emissions, I'm not really sure, but most people will tell you that what you're thinking about doing isn't worth it, and that it would be better to just replace the whole mid-pipe. I doubt that you'd notice a performance gain from cutting out 2 cats.
emissions also deal with the visual inspection, so you would fail off the bat because you're suppose to have as many cats on your car as it was stock, some stations don't care, you should check with your shop first, stock pipes are very expensive
you're better off buying a real hi flow h/x pipe with just 2 cats
back when i was looking at mustangs i test drove one that had the back to cats removed and stock mufflers turned down and it no tone at all sounded like a truck just get a mid pipe they arent that expensive i used to have a mac h-pipe and it was only $109 then i traded it and $75 for a o/r xpipe
