Dart 302 block, forged crank, rods, etc., etc...
TurboX2
Blaine, MN
EDIT: almost everything is sold, mods can delete this thread. Thanks.
Dart 8.2 deck block, stock 4.00 bore. New price ~$2000 plus machining. This one is decked and line honed, ready to run after a bore and hone. One cylinder has some nicks from a broken valve, probably take .030 or .040 over to clean it up, but its stock bore now and these things will go 4.185 (or more). The camera flash makes it look worse than it is. You can get JE 4.125 pistons for around $700 and pick up ~15 cubic inches and a bunch of airflow. Block price $1400.
Eagle 5.090 h-beam 4340 rods with L-19 bolt upgrade. $375
Eagle 4340 3.00 stroke forged crank. $350.
JE SRP stock bore pistons. 5 are good, one is a bit dinged but would clean up. Buy 2 new ones and have a low cost set. $100
This assembly was balanced together, if someone wants the crank and rods we can get a weight for one of the pistons, get your new pistons lightened to that weight and you'll be balanced and ready to go.
Crane roller conversion lifters. New price from Summit is $636, sell for $300
Crane Cams 36532-16 - Crane Hydraulic Roller Lifters - Overview - SummitRacing.com
TFS Stage III cam. New price is $200, sell for $100.
Trick Flow Specialties TFS-51402002 - Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L - Overview - SummitRacing.com
Cloyes roller timing chain. New price is $98, sell for $40.
Cloyes Gear 9-3135 - Cloyes Original True Roller Timing Sets - Overview - SummitRacing.com
Manley 6.85" pushrods. New price $147, sell for $50.
Manley 25685-16 - Manley Camshafts & Valvetrain - Overview - SummitRacing.com
Comp Cams Magnum 1.6 rocker arms. New price $275, sell for $175.
Ford Motorsport damper 50 oz imbalance. New price $275, sell for $150.
Ford Racing M-6316-A50 - Ford Racing Crankshaft Damper Assemblies - Overview - SummitRacing.com
Moroso oil pan & pickup tube. Paint is peeling some on the pan but its perfectly functional. New around $300. Also have a Melling oil pump & shaft. Had some debris in the pan so the pum should be taken apart and inspected, but it turns freely. Will throw the pump & shaft in for free, $150 for all.
Motorsport M-8501-B50 high volume water pump. New $205, sell for $75. Looks dirty but its just blower belt dust.
Ford Racing Maximum Flow Aluminum Water Pump - 1986-93 Ford 5.0L [M-8501-B50] - $204.95 : Buy Ford Racing Parts - Your only high performance parts & Ford Racing supplier for your Ford car or truck, When you want it done right and done well there is o
Z304 cylinder heads. 204cc. 63cc chambers. Double springs. Flow 270/210 as cast. This is a little preliminary as one is damaged, but thought I'd put it out there. I will be getting one new casting and a few new valves and freshening them up. They will be priced at $1000 at that time. Or, buy as-is for $400 and have them done up yourself.
Ford Racing valve covers & breathers. New $107+, sell for $70.
Ford Racing M-6582-L302 - Ford Racing Aluminum Valve Covers - Overview - SummitRacing.com
Edelbrock RPM Air Gap intake. New $255, sell for $175.
Edelbrock 7521 - Edelbrock Performer RPM Air-Gap Intake Manifolds - Overview - SummitRacing.com
MSD billet distributor #8579, MSD cap & rotor + spare cap & rotor, MSD plug wires & dividers. New $384 for all, sell for $225.
MSD Ignition 8579 - MSD Pro-Billet Distributors - Overview - SummitRacing.com
MSD Ignition 8431 - MSD Extra Duty Distributor Caps - Overview - SummitRacing.com
MSD Ignition 8467 - MSD Distributor Rotors - Overview - SummitRacing.com
MSD Ignition 31189 - MSD 8.5mm Super Conductor Spark Plug Wire Sets - Overview - SummitRacing.com
MSD Blaster 2 coil. New $36, sell for $25.
MSD Ignition 8202 - MSD Blaster 2 Ignition Coils - Overview - SummitRacing.com
MSD 6AL. New $198, sell for $125.
MSD Ignition 6420 - MSD 6AL CD Ignitions - Overview - SummitRacing.com
Complete exhaust. Very nice 1-3/4" ceramic coated longtubes w/ 3" collectors, wide exhaust pattern. Can't find a brand tag on them, but they are quality. BBK 2-1/2" x-pipe. Near new Flowmasters with turndowns. $700 for all.
Pickup only on the big stuff, unless someone buys a bunch of it I'll try to package for shipping, or maybe meet partway for a handoff. I've tried to price things fairly from the get-go, so prices are as stated unless buying multiple items I may discount a little. Happy shopping everyone! :flag:
I sincerely apologize for not replying guys, I didn't receive any email notification of replies to the thread, will have to check my settings. Anyway, I've sold almost everything, thanks for looking. :)
