do you still have a/c??? if so, replace the evap. core.... i know your up in michigan, so it may not have it.... just a thought though.... good luck with the heater core!!!
you may want consider pulling out any unwanted weight while you're in there. sound insulation and such. if you have a/c, is it functional? if not you could pull that out too.
Yeah I was thinking about the white faces, but I want to get a 140 or so speedo first. I got the weak 85MPH one...just don't have enough money to update yet.
Id pull all the a/c stuff and id check wires while i was under there. I did my heater core then i put a radio in my car and it wasnt working so i changed the fuse and smoke started to come out from under the dash. Two wires had corroded and were shorting out now its a big headache.
can you remove all the a/c stuff and still have heat? when i did mine, it looked like one big box. or can you get a heater box out of a non a/c car and replace the a/c box?
How hard was it man? my heater core is toast too..drove it last year without heat..never again! Any tips? I called Ford and they quoted me $490 in labour! ouch!
The hard part was getting the dash out far enough to get access to the core. I can not figure out what was holding it on the driver's side. I had everything disconnected, but something kept it in place. Then I took off two the the three bolts holding the core's box top on, and ended up breaking the top. But it worked out fine, because putting the new core in was a lot easier. All I did was put some poxy on where it broke and it seems to be fine. Just putting on some silcone to make a better seal.
