An FMU is used to ramp up fuel pressure under boost for injectors that are not large enough to supply ample volume. In a nut shell, an FMU is a bandaind fix for inadequate fuel injectors. larger injectors and a custom tune give much more of a precise control over the fuel curve. Optimum spray patterns for fuel injectors are at stock pressures. Ramping fuel pressure up to compensate for that smaller injector, makes those injector less efficient. Ramp the pressure up enough, and you run the risk of that injector locking itself open. Another potential risk with an FMU is the possibiilty of developing a hole or tear in the diaphram. Absolutely the worse thing that can happen to you. Imagine stepping on the gas, going into full boost, then discovering all too late that the FMU diaphram was damaged and you did not get the fuel you were supposed to. BANG! Game over. I've not heard of the latter happening all that often but it has happened. When it does though... there's no coming back from it.
