Decoding my VIN Plate
Mustangman66
Help with my VIN Plate!
Hi everyone, I'm a new owner of a 66 Coupe. The previous owner removed the VIN plate from the engine bay and I have decoded it. But the way the numbers match don't make any sense. If someone could tell me if I am decoding it correctly, I would be grateful. I put the numbers into an online decoder and I got an axle ratio of 3.89:1. That option was only available on the Hi Po package. I have a 289 2V V8. The VIN plate is as follows:
%563
8 K14 6T07C118583
65A R 26
RM 4 SPEED
Is the number "8" my axle code?? My driver side door is apparently from another Mustang so that really doesn't help me much. Thanks again!:)
Realmongo
I prefer to be called "Evil Genius"
2,340
44
99
Western Mass
%563
8 K14 6T07C118583
65A R 26
RM 4 SPEED
I can help with some.
K14: October 14
6: 1966 Model
T: Metuchen
07: Coupe
C: 289 2V
Production Number 18,583
65A: 2 Door Hardtop STD
R: Ivy Green
26: Black crinkle vinyl and black rosette pattern vinyl
RM: Remote Mirror
4 Speed Transmission
Mustangman66
Maybe the RM is the reason your driver's side door is gone. I have seen other numbers in place of the 8 so it is not related to the axle.
So the "8" does not give me the axle code? It seems like a valid replacement to the door tag which is not correct. Do you happen to know where the axle ratio stamping is on the axle so I can find it? And what about the door with the RM?? You think someone took the door off because of it?
Realmongo
2,340
44
99
Western Mass
I saw another tag that had 19 where yours has the 8. Sounds like it is time to crawl under the car to ensure it is an 8" rear and to read the axle ratio off of the tag. You never know about those RM doors, not many were made.
